Umbrella Stretcher to Rib Joint Repair
  1. Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the broken part of the stretcher to rib joint.
    • Realign it with the rib assembly.
  2. Umbrella Stretcher to Rib Joint Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the needle and carefully pass it through one of the holes as seen in the picture.
    • Then pull it back to the same side you went through.
  3. Umbrella Stretcher to Rib Joint Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the needle and pass it under the stretcher (not through the middle).
  4. Umbrella Stretcher to Rib Joint Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Position the needle so that it faces the second hole from the same side you just went through in step 3.
    • Take the needle and pass it through the second hole.
    • Then position the needle so that it faces the first hole from the same side you just went through.
  5. Umbrella Stretcher to Rib Joint Repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Umbrella Stretcher to Rib Joint Repair: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat steps 2-4 until the two pieces are held tightly together.
    • Tie a knot to secure it.
    • Refer to step six if the rib punctured the canopy.
  6. Umbrella Stretcher to Rib Joint Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Umbrella Stretcher to Rib Joint Repair: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It is easier to sew when the canopy is closed
    • Take the hole, hold each end and pull outward into a line.
    • Make sure that it is in line with the umbrella canopy seam.
    • Take the needle and thread and form a hemming stitch (see Step 7).
  7. Umbrella Stretcher to Rib Joint Repair: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Umbrella Stretcher to Rib Joint Repair: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Umbrella Stretcher to Rib Joint Repair: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin with a threaded needle and start the stitch at one end of the hole and pull the needle all the way until just before the thread runs out.
    • Then loop back around and go through again.
    • Repeat until you reach the other end.
    • You can form the stitch multiple times to make it more secure.
The umbrella is fixed now, you may now use the umbrella freely.
Rodrigo Soliva
crwdns2935283:010/26/17crwdne2935283:0
182 crwdns2915208:0crwdne2915208:0
DePaul University, Team S1-G8, Dush Fall 2017 crwdns2935289:0DePaul University, Team S1-G8, Dush Fall 2017crwdne2935289:0
DPU-DUSH-F17S1G8
I have a problem with the auto lock, it's a knight bridge umbrella, when i retract it, it doesn't lock in place, can it be fixed or replace the handle in case it's totally eroded?
kamec 01 - crwdns2934203:0crwdne2934203:0
I have 2 umbrellas which have both snapped at the hole. Is there a way this technique or a version of it can be used to repair them?
Jenny - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 171
crwdns2942667:0crwdne2942667:0 14,646
