Use this guide if you are experiencing a decline in audio quality in your Wonderboom 3 speaker. This guide will instruct you on how to replace the speaker drivers, which are critical for sound output. Over time or due to mishandling, these drivers can fail or degrade.
Before using this guide, it is important to note that this repair may affect the speaker's ability to be waterproof. Make sure the speaker is powered off.
To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
Take the top off of the speaker to reveal the inside of the speaker.
Carefully set the top cover to the side and make sure the clear plastic button tabs stay intact.
Take the mesh covering off of the speaker by pressing on the center of the speaker and pulling the mesh upwards.
Unscrew the four M3 x 6mm Phillips head screws in each corner of the speaker.
Using the metal spudger, slowly wedge it behind the speaker.
Slowly and gently push the spudger forward to dislodge waterproofing adhesive that holds the speaker in place.
Pull the speaker driver forward to dislodge it from the speaker.
Next, turn the speaker driver to where the wires are facing upwards.
Using the soldering iron, desolder the white and black wires (the 2 connections) at the top of the speaker driver.
