If your Udreamer turntable isn’t spinning properly, the belt might need to be replaced. The belt helps the platter spin so your records play correctly. If it's worn, you might notice slow or uneven spinning, or it might not spin at all.
Check the size of the current belt to ensure the correct replacement size. This video demonstrates how to measure if you are unsure of the size.
Before you begin the repair, unplug the turntable. Also, avoid touching the motor or any electronic parts to prevent damage to your unit.
Gently pull off the retaining clip at the center of the turntable platter.
Lift the platter straight up and off the spindle to reveal the belt and motor assembly underneath.
Carefully stretch the old belt off the motor pulley and platter grooves.
Position the new belt around the motor pulley and the inner rim of the platter.
Place the platter back onto the spindle, aligning it with the motor assembly.
Press the retaining clip back onto the spindle to secure the platter.
how do i know if the problem is the belt? it seems tight enough (i have no knowledge of this stuff). but it fits snug around the turntable thing but its still slow
