Is your drone propeller not functioning correctly? This guide will show you how to replace a damaged propeller blade on your Udi Discovery U818A FPV drone. You will need a Phillips head screwdriver size PH00 to complete this task.
Using the size PH00 Phillips screwdriver head, remove the 2mm screw from the base of the propeller blade.
Pull the propeller blade upward to separate it from the drone arm.
