UTStarcom XV6700 Screen Replacement
    1. UTStarcom XV6700 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press the on/off button on the top to power the phone off.
    2. UTStarcom XV6700 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery cover by pressing and sliding the cover down and off of the phone.
    3. UTStarcom XV6700 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the battery removal tab and lift the battery out of the phone.
      • If the battery removal tab is missing, place a spudger on the opposite side of the highlighted connector and pry the battery up.
    1. UTStarcom XV6700 Screen Replacement, Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 4.0-mm #000 Phillips screws at the top of the battery compartment. Tweezers may be useful to remove the screws.
    2. UTStarcom XV6700 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use firm pressure to carefully pry off the cover with your fingers.
    3. UTStarcom XV6700 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4.0-mm #00 Phillips screw securing the camera flash circuit board. The board is still connected by a connector on the bottom of the board.
    4. UTStarcom XV6700 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pry off the camera flash circuit board with the spudger.
    5. UTStarcom XV6700 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pry off the camera with the spudger.
    1. UTStarcom XV6700 Screen Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 5.0-mm Torx T6 screws from the corners of the black cover.
    2. UTStarcom XV6700 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4.0-mm #00 Phillips screw that holds the antenna in place. The antenna does not need to be removed.
    3. UTStarcom XV6700 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the spudger or plastic opening tools to apply firm but gentle pressure equally around the outside of the case.
      • Carefully pry the black portion of the case away from the silver portion.
      • Do not try to remove the case completely. The speaker wire is still connected to the motherboard.
    4. UTStarcom XV6700 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using tweezers, pull with gentle pressure in the direction of the wire to unplug from the motherboard connector.
    5. UTStarcom XV6700 Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4.0-mm #00 Phillips screw holding the motherboard in place. The screw is in the middle of the motherboard, near the outside edge.
    6. UTStarcom XV6700 Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • With your fingers, disconnect the keyboard cable from the motherboard. The cable is orange with the letters T/B printed on the connector.
    7. UTStarcom XV6700 Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully lift up on the motherboard with the spudger until you can see the display cable connected to the underside of the motherboard. The display cable connector will be taped over.
    8. UTStarcom XV6700 Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the spudger to peel away the tape from the connector.
    9. UTStarcom XV6700 Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the spudger, pry away the display cable connector from the motherboard. The motherboard is now completely disconnected.
    1. UTStarcom XV6700 Screen Replacement, Screen: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four 4.0-mm #00 Phillips screws that secure the slide-out keyboard to the screen enclosure.
    2. UTStarcom XV6700 Screen Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pull the display cable through the opening in the keyboard panel. The keyboard panel can then be set aside.
    3. UTStarcom XV6700 Screen Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove four 5.0-mm Torx T6 screws from the screen enclosure.
    4. UTStarcom XV6700 Screen Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pry the silver cover off the screen enclosure. The display cable should be pulled through the opening in the silver cover.
    5. UTStarcom XV6700 Screen Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the spudger to remove the tape from the connector between the screen and the front button circuit board.
      • Pry up on the brown connector to remove.
    6. UTStarcom XV6700 Screen Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove one 4.0-mm #00 Phillips screws from the silver bracket holding the screen assembly in place.
    7. UTStarcom XV6700 Screen Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 UTStarcom XV6700 Screen Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the screen by using the spudger to gently but firmly pry the screen away from the outer case.
      • Use your hand to lift the screen completely away from the case.
Tyson Janisch
crwdns2935283:006/04/13crwdne2935283:0
344 crwdns2915208:0crwdne2915208:0
University of Kentucky Louisville, Team 1-4, Chamberlain Spring 2013 crwdns2935289:0University of Kentucky Louisville, Team 1-4, Chamberlain Spring 2013crwdne2935289:0
LOUISVILLE-CHAMBERLAIN-S13S1G4
crwdns2935297:056crwdne2935297:0
crwdns2942667:0crwdne2942667:0 723
