UTStarcom CDM8945vw Keyboard Replacement
  1. UTStarcom CDM8945vw Keyboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the highlighted button in the direction in which the antenna is pointing. The battery will release and pop up.
  2. UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  3. UTStarcom CDM8945vw Keyboard Replacement, Antenna: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the antenna. It is the extendable plastic component pictured here.
  4. UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the base in a counter-clockwise motion to unscrew the antenna.
  5. UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The antenna should slide right out of the phone when finished.
  6. UTStarcom CDM8945vw Keyboard Replacement, Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small rubber grommet using the plastic opening tool.
  7. UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove five screws using a Phillips #00 screwdriver.
  8. UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to separate the two pieces that form the outer case of the phone.
    • Prying the two pieces apart may be difficult. Carefully apply a moderate amount of pressure when attempting to separate the two pieces or else you will risk breaking them.
  9. UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back piece of the outer case.
  10. UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker using a plastic opening tool.
    • Apply a small amount of force when removing the broken speaker from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  11. UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the wire attached to the speaker from the motherboard using tweezers.
    • Apply a small amount of force when removing the wire from the motherboard. If you apply a large amount of force, you may rip out the wires and damage the motherboard.
  12. UTStarcom CDM8945vw Keyboard Replacement, Logic Board: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the highlighted piece from the logic board using a plastic opening tool.
  13. UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UTStarcom CDM8945vw Keyboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the logic board from the anterior piece of the outer case using the plastic opening tool.
  14. UTStarcom CDM8945vw Keyboard Replacement, Keyboard: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard.
Bryon Hazlewood
crwdns2935283:010/03/12crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-26, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-26, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G26
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 343
