USB Cable Repair
  1. USB Cable Repair, USB Cable Repair: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 USB Cable Repair, USB Cable Repair: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 USB Cable Repair, USB Cable Repair: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the broken portion of the USB cable with the wire cutters.
    • You should now have two pieces of the cable left. If you had to remove the whole USB plug, you'll need a replacement plug.
    Preferably use a good quality sharp wirecutter to sever the wire. A dull or cheap wire cutter will crush it. Keeps integrity of wire intact
    Tex - crwdns2934203:0crwdne2934203:0
  2. USB Cable Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 USB Cable Repair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 USB Cable Repair: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Cut the outer cable covering with wire cutters or scissors of both cables and be careful not to cut the wires themselves.
    • Pull off the piece of cover that you've separated from the rest. You should be left with four exposed individual wires.
    • There should be four wires, and occasionally a piece of string too. If there are fewer wires, then you've clipped one off, and you need to start over.
    • If there are more than 4 wires, you probably have a USB 3.0 cable. In this case, make sure that whatever wires you'll be reconnecting are both USB 3.0.
  3. USB Cable Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 USB Cable Repair: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Strip all the wires out from both cables using a wire stripper. You'll need about three quarters of an inch of exposed copper wire.
    • If you don't have a wire stripper, you can strip the wires the same way as you exposed these wires. Gently cut the outer insulation, then pull off the insulation.
    • When stripping wires, do not cut or damage the copper wires. If you do damage the wire, cut off the damaged portion and try again.
  4. USB Cable Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 USB Cable Repair: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Oftmals sind die Drähte beschichtet und wollen gar kein Lot annehmen. Was sollte man dann machen?
    Lutz - crwdns2934203:0crwdne2934203:0
    Sie können die Beschichtung mit feinem Schleifpapier entfernen.
    Toon Konings -
  5. USB Cable Repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 USB Cable Repair: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 USB Cable Repair: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wrap each wire in electrical tape and make sure that there is no exposed copper showing.
    what if the cable snapped out of the mouse
    Keri Houck - crwdns2934203:0crwdne2934203:0
    Gebruik als laatste stap een krimpkous om alles goed in/af te sluiten 🤨
    fietsen met KBO - crwdns2934203:0crwdne2934203:0
    Gebruik als laatste krimpkous om alles goed in/af te sluiten 😎
  6. USB Cable Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 USB Cable Repair: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Wrap all the wires and both cables together in electrical tape to connect everything back into one cable and so it lasts longer.
    What if the wire is cut near one of the two ends how do you fix it then?
    Alis Shrestha - crwdns2934203:0crwdne2934203:0
    Instead of going through this, if the cable is wrecked by the end I would get a new cable. $10 will get you a 10' USB to C wire braided cable at Walmart. Good for home use charging phone. For laptop I would get something of better quality. Your office IT Support staff can help you there.
    Neal Jacobsen - crwdns2934203:0crwdne2934203:0
    Thanks Neil, but the whole purpose of this is to save on resources, and learn to be resourceful yourself.
    Every cable that I fix is one that I don't have to buy and $10 I have for something else!
    Robyn Stewardson -
    Heatshrink tubing will give you a more reliable and durable repair, just remember to slide it on before you do the soldering and slide it far enough away that your soldering iron doesn't prematurely shrink it.
    Juan Garcia - crwdns2934203:0crwdne2934203:0
Once your device is assembled and taped up then the repair is done and you can go back and do this multiple times.
crwdns2935229:038crwdne2935229:0
David
crwdns2935283:001/16/13crwdne2935283:0
1 271 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-36, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 18-36, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S18G36
crwdns2935297:030crwdne2935297:0
crwdns2947412:07crwdne2947412:0
What if it has a wire shield around it? Like crazy silver wires wrapped around it?
Bethany Marshall - crwdns2934203:0crwdne2934203:0
Then slowly wnwrap it not to remove it. And when u have repaired wires and taped them re wrap with silver shielding if it does have shielding it best to add a step to the repair and tbats to add a short section of shrink tubeing just big enough to cover spliced section and shielding. Once shielding is wrapped slid tubeing over repaired section and apply heat a hairdryer on high heat will work as well.
kotanwolf -
i tried solding the same wires but it still do not work
Faizan Ali - crwdns2934203:0crwdne2934203:0
Careful, not all USB cables use the same standardized colors. If you Frankenstein different cables together, you could match the wires improperly, causing damage to devices (like when reversing the voltage wires).
Jonathan Haas - crwdns2934203:0crwdne2934203:0
Professionals use heat shrink tubing on each wire, wrap the group with copper shielding tape, and then heat shrink over the group. You measure the tubing and add it to each wire before soldering. And make sure the final layer over the bundle is longer and extends at least ⅛" beyond both ends of the repair.
That will last.
Thank you very much 😊 Hope it helps.
Susan Holiday - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 46
crwdns2936753:07crwdne2936753:0 299
crwdns2936753:030crwdne2936753:0 1,233
crwdns2942667:0crwdne2942667:0 162,667
