UE BOOM 2 Motherboard Replacement
crwdns2942287:0crwdne2942287:0This guide will show how the motherboard of the UE Boom 2 Bluetooth speaker is removed. This is an extensive and intrusive process which removes all components of the speaker.
crwdns2944105:0crwdne2944105:0
First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
Remove by twisting in a counter-clockwise motion.
Remove the rubber port cover, peeling up from one end.
Remove the rubber stripping using a metal spudger.
Work around the edge of the rubber stripping slowly prying up the edge.
Continue removing the rubber stripping down the side.
On the bottom, unscrew the four 15mm Phillips head screws, using a #2 Phillips head screwdriver.
Pry up at the location marked, and remove the plastic end cap.
Now on the top, unscrew the four 15mm Phillips head screws, using a #2 Phillips head screwdriver.
Using the metal spudger, pry up the plastic cap at the point marked and remove the cap.
Carefully un-loop the cable with a plastic opening tool or spudger and unplug it from motherboard.
Pull out the battery, and handle with care.
Using the metal spudger, pry up the plastic tab on the inside.
Pry up around the entire inside circumference.
Repeat on the other end.
Using the metal spudger tool, pry up the inside edge of the mesh lining.
Working down the strip on both sides. Careful as to not rip the mesh.
Unscrew the two 5 mm Phillips head screws using a Phillips head #1 screwdriver.
Using the metal spudger, pry open the edge of the cover.
Using the metal spudger, pry the plastic casing up.
Repeat on the other side of the speaker.
Using the metal spudger, specifically the pointy end, find the gap between the speaker and the passive radiator (the larger rectangular speaker-like-object next to the speaker).
Pry the metal wire up and out at exactly this gap, then slide down wire towards one end to pop it out completely.
Once one end is out, use your fingers to gently pull off completely so as not to bend the wire too aggressively.
Repeat previous process for other side of the speaker and passive radiator (boxed).
Using the metal spudger, work it under the passive radiator.
Work the passive radiator up around all edges, and pull out of casing.
With the passive radiator removed, pry up the pink rubber seal using a metal spudger.
Remove using fingers.
Using the metal spudger, work it under the edge of the speaker.
Work around the speaker on all sides.
Once speaker is detached from casing, remove cable from motherboard.
With both the speaker and passive radiator removed from one side of the Boom 2, repeat steps 13-18 for the other side.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Using angled tweezers, pull up the black sheath on tan connector port.
Gently pull the white ribbon cable out from connector.
With the ribbon cable disconnected from the motherboard, remove the Bluetooth antennas.
Confirm that all cables from speakers, Bluetooth antenna, and battery have been disconnected from the motherboard.
Grab the single piece of green motherboard that runs perpendicular to the motherboard, and pull out of casing.
There was a lot of white glue around the rubber seals. Even after removing excess glue residue it is very difficult to get speaker tight enough to fit retaining wires in that hold speakers down. Any easy way of doing this?
Buenas tardes
Disculpe las molestias. En mi equipo ue boom 2 no sale audio, ya desarme siguiendo los paso y medi Ω de sus parlantes, y estan en su valor me puede ayudar con este problema.
O se puede cambiar toda la tarjeta madre.
Le agradezco de antemano .
Estare atento a cualquier respuesta.
Where can I get a new motherboard or get my current one repaired?
My Boom 2 won’t respond. Doesn’t make any sounds when pressing bottoms, and Bluetooth doesn’t work. If it’s connected to power and using an aux cord it works. But unless connected to power the speaker won’t turn on or work at all. I checked the condition of the battery and it’s voltage was perfect. Could this problem be to do with the mother board and would replacing it fix these problems. Any advice you have would be brilliant. Thanks
