UE BOOM 2 Micro-USB Port Replacement
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 UE BOOM 2 Micro-USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 UE BOOM 2 Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 UE BOOM 2 Micro-USB Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
    The rubber is glued to a hard plastic part of the case that is snapped in. Must remove the hard plastic that the rubber is attached to. Not just the rubber.
    Jordan Baxter (jbax92) - crwdns2934203:0crwdne2934203:0
  4. UE BOOM 2 Micro-USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 UE BOOM 2 Micro-USB Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 UE BOOM 2 Micro-USB Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
crwdns2935229:08crwdne2935229:0
Alex Bahm
crwdns2935283:001/18/18crwdne2935283:0
2.319 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S12-G5, Banghart Winter 2018 crwdns2935289:0Cal Poly, Team S12-G5, Banghart Winter 2018crwdne2935289:0
CPSU-BANGHART-W18S12G5
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - crwdns2934203:0crwdne2934203:0
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - crwdns2934203:0crwdne2934203:0
i too am looking to find the replacement part
Liam Nicholls - crwdns2934203:0crwdne2934203:0
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - crwdns2934203:0crwdne2934203:0
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - crwdns2934203:0crwdne2934203:0
I want to have the UE Boom 2
Fixed because it stopped charging while plugging my UE Boom 2
Shannon Leclair - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 10,049
