This guide shows how to replace an ineffective or broken speaker in a Turtle Beach PX22 headset. Soldering skills are needed for this job.
Use your fingers to peel off ear cushion by pinching and pulling off the leather.
Use a Phillips #00 head screwdriver to remove the three screws located around the speaker (9/32 in length, 1/8 inch head).
The housing will come loose. Take note of the position of the wires connected to the speaker.
Desolder the colored wire and copper wires.
Does the speaker driver separate from the surrounding plastic disk, so it can be replaced with a like-sized driver, or is the driver plus mounting plate assembly sold as a replacement part?
Where can a new speaker be purchased? It says that there are no parts required but in step 3 it says to have a new speaker. I can't find this online.
