This guide will assist users in replacing the right speaker with a new speaker. It will be useful for users whose right speaker is no longer producing any sound or is producing sound that is broken and scratchy.
Firmly pinch ear cushion between thumb and forefinger.
Using the hand not holding the ear cushion, grasp the orange plate that is below the ear cushion.
Rotate ear cushion counter-clockwise about half an inch.
After it has audibly snapped out of place, lift the ear cushion off of the device.
Using the new cushion, align the pegs located on both the orange plate and ear cushion.
Once the pegs are aligned, push the new ear cushion in place.
Remove the right ear cushion.
Using the Phillips #0 screwdriver, remove the 6.0 mm screws on the orange plate.
Use the opening tool to separate the orange plate from the black base plate.
Focus on the wires that are connected to the speaker.
Cut the two wires that are attached to the speaker.
Replace the old speaker with the new speaker.
Using the soldering iron, solder the wires to the new speaker.
