The slide adjustment lets you make the headset more comfortable. If it malfunctions, you can replace the slide adjustment mechanism in your Turtle Beach Ear Force XO Seven Headset with this guide.
Remove the two 1.0 cmTorx T6 screws using the matching Torx T6 screwdriver.
Insert the spudger into the gap between the leather and plastic.
After making sure you have a good grip, use the spudger to pry the two plastic pieces apart.
crwdns2947412:07crwdne2947412:0
What if the plastic part that connects the earphones to the headband breaks and is there a way I can fix or replace that ??
I really don't want to buy another turtle beach headset
James did you ever find a solution because I have the same problem
Same problem here commandcorps.
adampm1 -
Same problem… plastic slide adjustment broke… contacted turtle beach and haven’t heard back… it should be an easy fix but can’t find the parts anywhere thus far…
