Tungsten E Power Button Repair
  1. Tungsten E Power Button Repair, Tungsten E Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tungsten E Power Button Repair, Tungsten E Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Power Button Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
  3. Tungsten E Power Button Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Power Button Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Power Button Repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Power Button Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
  7. Tungsten E Power Button Repair, Tungsten E Power Button Repair: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  8. Tungsten E Power Button Repair: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • On the motherboard, find the power button near the upper right corner.
    • Check for disconnection of the power button.
  9. Tungsten E Power Button Repair: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use soldering iron to reattach the damaged power button to the motherboard.
Kathleen Hix
crwdns2935283:001/21/10crwdne2935283:0
49 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-22, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 13-22, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S13G22
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 5,269
