Tungsten E Power Button Repair
crwdns2869540:0crwdne2869540:0: 5.9 k
2
21
88
5,852
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
How to repair a loose power button.
    1. Tungsten E Power Button Repair, Tungsten E Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tungsten E Power Button Repair, Tungsten E Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the stylus and SD card.
      • Using a T5 torx screwdriver, remove all 4 back panel screws.
      • The screws are small and can be lost easily. Be sure to place them in a secure area.
    2. Tungsten E Power Button Repair: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a plastic opening tool under the USB and power input slots.
      • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
    3. Tungsten E Power Button Repair: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Your device may not have a screen protector. If not, you can move on to step four.
      • Remove the screen protector by lifting the hinge out of the plastic housing.
      • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
    4. Tungsten E Power Button Repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
      • Using a spudger, unlock both sides of the flex connector block by pushing down.
      • Remove motherboard completely.
      • Metal washers may pop out of the device during this step
    5. Tungsten E Power Button Repair: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Tungsten E Power Button Repair: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove buttons using fingers.
      • Gently flex frame to release screen from plastic frame.
      • Lift out screen.
    6. Tungsten E Power Button Repair: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Congratulations! You have successfully taken apart a Palm Tungsten E.
    1. Tungsten E Power Button Repair, Tungsten E Power Button Repair: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    2. Tungsten E Power Button Repair: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • On the motherboard, find the power button near the upper right corner.
      • Check for disconnection of the power button.
    3. Tungsten E Power Button Repair: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use soldering iron to reattach the damaged power button to the motherboard.
Kathleen Hix
crwdns2935283:001/21/10crwdne2935283:0
49 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-22, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 13-22, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S13G22
crwdns2935297:048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 88
crwdns2959996:0crwdne2959996:0 5,852
