Trust GXT 545 Wireless PC-PS3 Controller Disassembly
  1. Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the back of the controller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the back of the controller: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip over the controller.
    • Then, unscrew the 7 screws holding it together.
    • There are no screws hiding under the sticker, so there is no need to rip it off or punch a hole in it (like i tried to do in a previous attempt)
    • After removing the screws, just pull the back off of the controller. There aren't any cables attached to it.
  2. Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the main board and vibration motors.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the main board and vibration motors.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, unplug the battery connector
    • Then, undo the 8 clips that hold the board to the front casing with the flathead driver.
    • For the lower clips, you might need a slightly bigger flathead.
    • After that, just lift the board up.
    • Be careful not to break the wires that go to the vibration motors, as they are soldered to the board.
    • To remove the vibration motors, just pull them out, being careful not to break the wires.
  3. Trust GXT 545 Wireless PC-PS3 Controller Disassembly, Removing the buttons (only for complete disassembly): crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws holding the D-pad and buttons to the front case, carefully prying them out with your flathead. To remove the shoulder buttons, just pull them out.
    • Unfortunately, the clear lenses through which the status LEDs shine are glued onto the case and are not removable.
  4. Trust GXT 545 Wireless PC-PS3 Controller Disassembly, You are done!: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You now have a fully disassembled controller, ready to be repaired or modified
niccotaglia
crwdns2935283:002/25/16crwdne2935283:0
324 crwdns2915208:0crwdne2915208:0
Hello, I got this one (wired version) and I want to change joysticks as they are pretty much trash for analog control (joystick sensitivity). I want to use potenciometer ones as they are mostly used in premium brands such as microsoft and sony. What can I use? are there any things to be aware of? Any compatibility issues? I know how to disassemble it and solder it on. I just need to know which to get. I found ones from local shop called "Potenciometr Joystick PS4 JDM-055". ******Thanks for any response and have a great day :)
Creepy SK - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 59
crwdns2942667:0crwdne2942667:0 6,191
