This guide outlines how to properly remove the air filter on a Troy-Bilt TB675 EC. The guide also explains how to clean the air filter.
Remove the air filter housing by turning the plastic screw counterclockwise with your hand.
Remove the air filter that lays beneath the housing you removed in step 1.
Clean the air filter thoroughly by spraying compressed air through the filter.
Wipe all oil and water residue around the air filter casing with a paper towel or rag.
Place the air filter and air filter casing back in its original position.
Complete the maintenance by turning the screw clockwise with your hand until it is fully secured.
crwdns2917034:0crwdne2917034:0
I believe you may have missed the small detail of giving us a part #.
That would’ve been VERY helpful.
