Tritton Kunai Right Speaker Replacement
  1. Tritton Kunai Right Speaker Replacement, Right Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tritton Kunai Right Speaker Replacement, Right Speaker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grasp the black ear cushion with one hand and the white speaker frame with the other hand.
    • Forcibly pull the ear cushion and speaker frame in opposite directions, until the right ear cushion separates from the right ear frame.
  2. Tritton Kunai Right Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tritton Kunai Right Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 9 mm screws indicated in red with a PH00 screwdriver.
    • Remove the two 7 mm screws indicated in orange with a PH00 screwdriver.
    • Separate the black horseshoe shaped frame from the right speaker frame.
  3. Tritton Kunai Right Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tritton Kunai Right Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black bracket and then the rail adjustment from the right speaker frame.
  4. Tritton Kunai Right Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tritton Kunai Right Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 7 mm screws indicated in red using a PH00 screwdriver.
    • Separate the black speaker console from the right speaker frame.
  5. Tritton Kunai Right Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the red and green wires from the 16 Ohm speaker.
  6. Tritton Kunai Right Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze the tip of the tweezers into the gap between the speaker and the speaker case.
    • Remove the glue holding the speaker in place by scraping the glue with the tip of the tweezers.
  7. Tritton Kunai Right Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tritton Kunai Right Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker from its circular shaped slot.
    • Apply glue to the sides of your new 16 Ohm speaker.
  8. Tritton Kunai Right Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Tritton Kunai Right Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your new speaker into the circular shaped slot located on the speaker cover.
  9. Tritton Kunai Right Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder the wires you disconnected from the old speaker to the new speaker. The red wire is to be soldered to the far right terminal, while the green wire is to be soldered to the far left terminal.
    • Here is iFixit's soldering guide.
    • Solder with caution and try not to burn yourself.
To reassemble your device, follow steps 1 through 4 in reverse order.
Elias El Tom
crwdns2935283:003/12/15crwdne2935283:0
338 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-3, Duarte Spring 2015 crwdns2935289:0UMass Dartmouth, Team 3-3, Duarte Spring 2015crwdne2935289:0
UMASSD-DUARTE-S15S3G3
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,241
