Trio Stealth-10 Speaker Replacement
  1. Trio Stealth-10 Speaker Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Speaker Replacement, Speaker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  3. Trio Stealth-10 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
Daniel Coleman
crwdns2935283:010/29/15crwdne2935283:0
643 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-4, Miles Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-4, Miles Fall 2015crwdne2935289:0
UMASSD-MILES-F15S1G4
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 354
