Trio Stealth-10 Motherboard Replacement
  1. Trio Stealth-10 Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Motherboard Replacement, Speaker: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This next step will require you to solder a couple of wires off the motherboard. We recommend you get someone to help you if you are unfamiliar with soldering or use Ifixit's Soldering guide to help you.
    • Next you must solder off the wires that connect the speaker to the motherboard.
  3. Trio Stealth-10 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next you will need to remove the two screws attached to the speaker. If you have a 54 bit Driver Kit use the Philips Head 0 (or PH 0) head to remove the two 4mm screws.
  4. Trio Stealth-10 Motherboard Replacement, Front-Facing/ Rear-Facing Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  5. Trio Stealth-10 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  6. Trio Stealth-10 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the first layer of tape above camera cable connection slowly.
  7. Trio Stealth-10 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
  8. Trio Stealth-10 Motherboard Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step will require soldering. If you are unfamiliar with soldering then we recommend that you get help from another person or use the soldering guide made by Ifixit to help.
    • Solder the connections off for the battery.
  9. Trio Stealth-10 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Trio Stealth-10 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the screen/digitizer connection. Use tweezers and pull each grey end of the connection until there is a small gap between the grey and white on the connector to the motherboard. The connection should be easily removable.
    • Pull the cable away and clear from under the battery to avoid damage to the connection.
  10. Trio Stealth-10 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry battery up from adhesive. Use a type of adhesive remover. Nail polish remover works well.
  11. Trio Stealth-10 Motherboard Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your spudger to disconnect the screen/digitizer connection from the motherboard.
  12. Trio Stealth-10 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Trio Stealth-10 Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to grasp the screen/digitizer connection gently and remove each accordingly.
  13. Trio Stealth-10 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the EDC tape with your tweezers and lift it off gently from the motherboard and set aside to be reused.
  14. Trio Stealth-10 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Trio Stealth-10 Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 to unscrew the 4mm screws from the motherboard fixture.
  15. Trio Stealth-10 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure that all the connections to the motherboard are disconnected. Proceed to remove the motherboard by slowly tilting it away from you and then lifting it straight up.
crwdns2935229:05crwdne2935229:0
Daniel Coleman
crwdns2935283:010/29/15crwdne2935283:0
643 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-4, Miles Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-4, Miles Fall 2015crwdne2935289:0
UMASSD-MILES-F15S1G4
crwdns2942667:0crwdne2942667:0 1,618
