Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
  1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the first layer of tape above camera cable connection slowly.
  5. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
Daniel Coleman
crwdns2935283:010/29/15crwdne2935283:0
643 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-4, Miles Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-4, Miles Fall 2015crwdne2935289:0
UMASSD-MILES-F15S1G4
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 487
