The speakers play audio out the device. If your tablet does not emit sound then your speakers may be faulty. This guide will help you remove the speaker.
Use your thumbs to slide up and off the small SD card case.
Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
Unscrew the two 4 mm #000 screws.
Use a soldering iron to desolder the speaker connection.
