Trio AXS 3G Battery Replacement
crwdns2869540:0crwdne2869540:0: 1.9천
21
83
1,949
crwdns2955950:0crwdne2955950:0: 2
crwdns2960008:02crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 15 - 30 crwdns2931279:0crwdne2931279:0
If your tablet's battery no longer holds a charge, this guided will show you how to replace it with a new one.
    1. Trio AXS 3G Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
    2. Trio AXS 3G Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Trio AXS 3G Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
    3. Trio AXS 3G Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
    1. Trio AXS 3G Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The battery is the large, silver square inside the tablet. It is connected to the motherboard by two wires.
    2. Trio AXS 3G Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the soldering iron to remove the two metal ends that connect the battery to the motherboard.
    3. Trio AXS 3G Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Plastic Cards
      $2.99
      • Use the plastic card to pry the battery away from the device.
      • The battery is attached to the tablet by glue.
    4. Trio AXS 3G Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Peel off the battery from the device to completely remove it.
Michaela Causey
crwdns2935283:009/20/17crwdne2935283:0
328 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S7-G6, Thomas Fall 2017 crwdns2935289:0University of North Texas, Team S7-G6, Thomas Fall 2017crwdne2935289:0
UNT-THOMAS-F17S7G6
where can i buy a battery replacement? can it work without a battery?
millie abanilla - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
where can you buy a replacement battery
J W - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 83
crwdns2959996:0crwdne2959996:0 1,949
