Triace A310 Chain Replacement
    1. Triace A310 Chain Replacement, Tire: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Begin loosening the tire by turning the quick release handle.
    2. Triace A310 Chain Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
      • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
    3. Triace A310 Chain Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • There should be enough slack, in the chain, at this point to remove the tire from the bike.
      • Note: You may need to wiggle the tire and chain around in order to create enough slack.
      • Remove the tire from the bike.
    1. Triace A310 Chain Replacement, Chain: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement, Chain: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement, Chain: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the master link along the chain.
      • Note: If the master link matches the one pictured in this step continue with the instructions, if not skip to the next step.
      • With pliers squeeze the two pins together so that the chain comes apart.
    2. Triace A310 Chain Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Note: This step is only for chains with a master link clip.
      • With a plier press the two pins together and remove the clip.
      • Once the clip is removed the chain should easily come apart.
    3. Triace A310 Chain Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the chain is separated, remove it from the bike by pulling one end.
    4. Triace A310 Chain Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • With the new chain, place it on the current gear that your bike is in.
      • Note: If you don't know which gear your bike is in place the chain on one of the middle gears.
      • Thread one end of the chain through the derailleur from top to bottom so it is in the shape of a 'S'.
      • Next place the chain on the back gears, making sure that it is threaded through the guide.
    5. Triace A310 Chain Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To reassemble the chain bring both ends of the chain together so that the pins on each one lineup.
      • Grip the chain on both sides of the master link and pull.
    6. Triace A310 Chain Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Triace A310 Chain Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • If your chain does have a master link clip replace the link around the two pins.
      • Use a plier to slide the clip back into place.
Once your chain is back together, you are ready to once again, hit the trails.
Jacob Rickman
crwdns2935283:001/26/14crwdne2935283:0
159 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-37, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 1-37, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S1G37
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 1,305
