crwdns2959928:0crwdne2959928:0 ↓When your brakes get worn down, they need to be replaced. This will help keep you safe as you ride.
Unscrew the brake pad cap with a T25 screwdriver bit.
Grab and pull out the spring between the brake pads.
Slide out the back brake pad first. Then slide out the front brake pad.
Slide in the new brake pads with the first going in the front.
Then slide in the other pad in the back.
Push the spring back into place between the two brake pads so the spring is visible in the hole shown here.
Adjust the red knob as necessary (directions are noted on the knob).
Now your bike should actually be able to stop.
