Triace A310 Brake Cable Replacement
  1. Triace A310 Brake Cable Replacement, Brake Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Triace A310 Brake Cable Replacement, Brake Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • WARNING: Be sure to follow each step carefully. Failure to do so may result in serious injury or death.
    • Unscrew the screw holding the brake cable in place with a 5mm allen wrench and pull out the cable.
  2. Triace A310 Brake Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Triace A310 Brake Cable Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Triace A310 Brake Cable Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the slotted brake cable cap on the rear tire and pull out the cable. Remove the cap from the cable.
  3. Triace A310 Brake Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Triace A310 Brake Cable Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the cap next to the brake handle and remove it from the cable.
  4. Triace A310 Brake Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Triace A310 Brake Cable Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Triace A310 Brake Cable Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up and out on the cable to remove the barrel nipple (the small cylinder at the end of the cable).
  5. Triace A310 Brake Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Triace A310 Brake Cable Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Triace A310 Brake Cable Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the bracket located on the front tire with a 3mm allen wrench.
    • Rotate the bracket 90 degrees or until the opening is large enough for the cable. Remove the cable.
    • Note that if removing cable for rear brake, rather than unscrewing a bracket, you will unclip several "spring" clips. Keep track of clips.
    • Test your brakes in a low-speed environment to ensure that they work.
To place the new cable, follow these instructions in reverse order.
Ben Hartinger
crwdns2935283:001/27/14crwdne2935283:0
340 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-37, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 1-37, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S1G37
crwdns2935297:011crwdne2935297:0
crwdns2942667:0crwdne2942667:0 415
