Treblab HD77 LED Light Replacement
    1. Treblab HD77 LED Light Replacement, Surround: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement, Surround: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement, Surround: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the outer casing of the speaker by prying at the edges to unlock each prong holding the casing to the speaker.
    2. Treblab HD77 LED Light Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the plastic ring on top of the rubber surround on the side of the speaker by lifting it gently.
      • There is a layer of adhesive between the plastic ring and the rubber surround beneath it.
    3. Treblab HD77 LED Light Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the blade of a small precision knife between the edge of the rubber surround and the plastic edge.
      • Gently apply pressure and slide the blade in a circle along the entire circumference until the surround loosens and can be removed.
      • There is a layer of adhesive between the surround and the plastic housing it is resting on.
    1. Treblab HD77 LED Light Replacement, LED Light: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement, LED Light: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement, LED Light: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide a small precision knife underneath the LED light strip and remove the adhesive holding it in place.
      • There are four points where adhesive is used to hold the LED light strip down.
      • Lift up the LED light strip from the plastic casing.
    2. Treblab HD77 LED Light Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Treblab HD77 LED Light Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the LED light strip upside down to see where the cord is plugged in.
      • Gently pinch the wire with your pointer finger and thumb, and remove the cord from the LED slowly.
      • The cord is very thin and lightweight so use caution when handling.
Matthew Szabo
crwdns2935283:011/04/25crwdne2935283:0
775 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-5, Biswokarma Fall 2025 crwdns2935289:0UMass Dartmouth, Team 3-5, Biswokarma Fall 2025crwdne2935289:0
UMASSD-BISWOKARMA-F25S3G5
crwdns2942667:0crwdne2942667:0 210
