Traxxas Ford Fiesta ST Rally Motor Replacement
  1. Traxxas Ford Fiesta ST Rally Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove each of the four pins that hold the scale model shell by pulling them from their posts.
    • Remove the shell by lifting it off the chassis using your hands.
  2. Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3x6 mm screw holding the wire retainer in place using a 2.5 mm hex key.
    • Remove the wire retainer by lifting it off the chassis.
  3. Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This guide was done without a battery present. Please remember to properly disconnect any batteries before this step as it could cause injury to you or damage to the device.
    • Disconnect both power cables attaching the electronic speed control to the motor.
  4. Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3x15 mm retaining bolt using the 3 mm hex key.
    • Remove the 3x6 mm flat head screw holding the motor plate in place with the 3 mm hex key.
  5. Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the 2.5 mm hex key to remove the 3x6 mm screw for the gear cover.
    • To remove the cover, simply lift it up and off of the chassis.
    • During reassembly, ensure that the motor and gearing line up just how it is in the second photo for this step.
  6. Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the motor by rotating and lifting it free from the chassis.
    • You may need to clean the area where the new motor will be to prevent the possibility of debris becoming a problem for a newly replaced engine.
  7. Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Traxxas Ford Fiesta ST Rally Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the 2.5 mm hex key to loosen the 3x8 mm screws to remove the motor plate.
    • Use the 2 mm hex key to loosen the 3 mm grub screw enough to remove the pinion gear from the motor.
    • Slide the pinion gear right off the motor's external rod when loose enough.
    • Make sure to have the pinion gear in the exact same area as it was on the replaced motor in order to align with the device's gearing.
    • This process can also be used to put an even better motor in as a replacement during reassembly.
Follow these instructions in reverse order to reassemble your device using the new/functioning motor.
Joshua Bailey
crwdns2935283:001/28/22crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 8-8, Briggs Spring 2022 crwdns2935289:0CSU Los Angeles, Team 8-8, Briggs Spring 2022crwdne2935289:0
CSULA-BRIGGS-S22S8G8
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 821
