Touchpad with Spacers Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Touchpad with Spacers Removal, Before you begin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Touchpad with Spacers Removal, Before you begin: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Touchpad with Spacers Removal, Remove the touchpad spacers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Touchpad with Spacers Removal, Remove the touchpad spacers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Touchpad with Spacers Removal, Remove the touchpad spacers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  3. Touchpad with Spacers Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the same procedure for the other touchpad spacer.
  4. Touchpad with Spacers Removal, Remove the touchpad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Touchpad with Spacers Removal, Remove the touchpad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Touchpad with Spacers Removal, Remove the touchpad: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
168,838 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,281crwdne2935297:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 18
