Toto E-Max Fill Valve Disassembly
  1. Toto E-Max Fill Valve Disassembly, Tank Lid: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Tank Lid: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Tank Lid: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the tank lid up and away from the toilet tank.
  2. Toto E-Max Fill Valve Disassembly, Shutting off the Water Supply to a Toilet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Shutting off the Water Supply to a Toilet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Shut off the stop valve underneath the toilet by turning it clockwise until it becomes hand tight.
    • The appearance of this valve may differ from toilet to toilet, but most operate the same. Some valves require multiple turns to stop the water while others only require a quarter turn.
  3. Toto E-Max Fill Valve Disassembly, Refill Tube: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Refill Tube: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Refill Tube: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the fill valve's rubber refill tube from the top of the overflow tube.
  4. Toto E-Max Fill Valve Disassembly, Draining a Toilet Tank: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Draining a Toilet Tank: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push down the flush lever.
    • Hold the lever down until water stops draining from the tank.
    • A small amount of water will remain in the bottom of the tank.
    • If the flush lever or pull chain have become disconnected, lift up the toilet flapper to drain the tank.
  5. Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Sponge Drying a Toilet Tank: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a sponge to soak up and remove any remaining water from the toilet tank.
    • Periodically squeeze the excess water from the sponge.
  6. Toto E-Max Fill Valve Disassembly, Supply Tube: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Supply Tube: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Supply Tube: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a bucket under the supply tube to catch any dripping water.
    • Turn the coupling nut on the supply tube clockwise until it releases from the threaded shank on the bottom of the tank.
  7. Toto E-Max Fill Valve Disassembly, Fill Valve: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Fill Valve: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an adjustable wrench, turn the locknut on the threaded shank counter-clockwise until it becomes loose.
  8. Toto E-Max Fill Valve Disassembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toto E-Max Fill Valve Disassembly: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the locknut counter-clockwise until it releases from the threaded shank.
  9. Toto E-Max Fill Valve Disassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toto E-Max Fill Valve Disassembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the entire fill valve out of the tank.
    • When installing a new valve, be sure to adjust the float so that the water line stops one inch below the overflow tube.
  10. Toto E-Max Fill Valve Disassembly, Valve: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is our friend the Toto E-Max Fill valve. Unfortunately, she is leaking. Specifically, the shutoff is incomplete, so water continues to flow even after the float is fully lifted.
  11. Toto E-Max Fill Valve Disassembly, Remove Top Cap: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The next step is to remove the green top cap. It's held on by tabs, light flexing should allow you to remove it.
  12. Toto E-Max Fill Valve Disassembly, Remove the valve lever: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here is the valve lever[*]. We need to remove it. It's held in by two pegs. Each one is attached to a flexible tang. use a thin blade or screwdriver to push each tang in, while gently lifting the lever.
    • [*} I have no idea if this is the right name.
  13. Toto E-Max Fill Valve Disassembly, Continue removing valve lever: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here we see one peg released. Note that I'm applying very gentle lifting pressure, not prying it upward.
  14. Toto E-Max Fill Valve Disassembly, Release one end of valve lever: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Valve lever released! You are a champion. BTW, I made up the name "valve lever". I hope you're not laughing at me.
  15. Toto E-Max Fill Valve Disassembly, Release other end of valve lever: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the other end of the valve lever. You should be able to easily release it from the green collar.
  16. Toto E-Max Fill Valve Disassembly, Remove the collar: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, gently pop off the green collar that links the valve lever to the threaded float lift shaft.
  17. Toto E-Max Fill Valve Disassembly, Disconnect float pole from top cap: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Disconnect float pole from top cap: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently snap the white float pole out of the jaws of the top cap. When you do this, the float assembly will drop.
  18. Toto E-Max Fill Valve Disassembly, Rotate valve cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the valve cover an eighth of a turn counter-clockwise to release it.
  19. Toto E-Max Fill Valve Disassembly, Admire valve seal: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toto E-Max Fill Valve Disassembly, Admire valve seal: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Yay! We got to the valve seal. Clean it off or replace it, and reverse steps to reassemble.
crwdns2935229:05crwdne2935229:0
John Clements
crwdns2935283:011/05/17crwdne2935283:0
618 crwdns2915208:0crwdne2915208:0
Thank you! I did not expect to find a guide for a Toto toilet repair on a (mainly) electronics site, but here it is!
It worked perfectly when my toilet started running continuously on a Saturday evening.
I was able to take everything apart without even removing it from the tank, so it was a 15min fix!
Thank you!
Graham Allen - crwdns2934203:0crwdne2934203:0
Red rubber flapper that covers the water hole doesn't line up when flushed. Replaced it, tried to adjust the chain. Still same, lands too far to left amd water continues to leak into bowl.
Toilet Questioner - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 97
crwdns2942667:0crwdne2942667:0 2,970
