Toshiba Thrive Screen Replacement
crwdns2869540:0crwdne2869540:0: 2.1K
2
23
90
2,120
crwdns2955950:0crwdne2955950:0: 4
crwdns2960004:03crwdne2960004:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: 25 - 30 crwdns2931279:0crwdne2931279:0
    1. Toshiba Thrive Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure the lock switch for the back cover is unlocked.
      • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
    2. Toshiba Thrive Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove back cover by prying away from the Thrive.
      • The easiest place to pry from is one of the two speakers.
    3. Toshiba Thrive Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To remove the battery, make sure the lock switch is in the unlocked position.
      • The battery is unlocked when the switch is slid to the unlocked position.
    4. Toshiba Thrive Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Slide the battery switch release to the right.
      • While holding the switch in place, lift up the battery.
    1. Toshiba Thrive Screen Replacement, Midframe: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Thrive Screen Replacement, Midframe: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
      • All of these screws are identical so don't worry about getting them mixed up.
    2. Toshiba Thrive Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Start to gently pry the back of the device off, while leaving it loosely in place.
      • Be careful not to tear or damage the cables when removing the back.
    3. Toshiba Thrive Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
    4. Toshiba Thrive Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully open the device like a book and lay the two halves beside each other.
    1. Toshiba Thrive Screen Replacement, Front Camera: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Thrive Screen Replacement, Front Camera: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Separate the two halves of your Thrive
      • Using a Phillips screwdriver, remove the six screws holding the LCD in place. These screws are 3mm in length and require a PH0 screwdriver.
    2. Toshiba Thrive Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • With a spudger, disconnect the cable connecting the camera to the motherboard.
    3. Toshiba Thrive Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift up the LCD from the screen and place it on the side
    4. Toshiba Thrive Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Thrive Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the one screw holding the camera in place. The screw is 3mm in length and requires a PH0 screwdriver.
      • Lift up the camera from the screen.
Kason
crwdns2935283:009/22/14crwdne2935283:0
1,120 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-1, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 10-1, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S10G1
Indicate which tools are needed at the top of each guide.
Dan Brown - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 90
crwdns2959996:0crwdne2959996:0 2,120
