Toshiba Tecra Z50-A Motherboard Replacement
  1. Toshiba Tecra Z50-A Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn off the laptop.
    • Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
    • Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
  2. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up back panel using your hands and remove it from the rest of the laptop.
  3. Toshiba Tecra Z50-A Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the plastic covering over the battery plug.
  4. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wired cable up towards the top of the laptop to disconnect it from its socket on the motherboard.
  5. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 2 mm screw from the corner of the laptop using a Phillips #0 screwdriver.
  6. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3 mm screws from the battery using a Phillips #0 screwdriver.
  7. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the battery with your hands and remove it from the laptop.
  8. Toshiba Tecra Z50-A Motherboard Replacement, CPU Fan and Heat Sink: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3 mm screws from the heat sink using a Phillips #0 screwdriver.
  9. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm screws from the fan using a Phillips #0 screwdriver.
  10. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heat sink from the laptop.
  11. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull towards the bottom of the laptop to disconnect the fan cable from its connector on the motherboard.
  12. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the fan and remove it from the laptop.
    • When replacing the fan and heat sink, be sure to reapply thermal paste.
  13. Toshiba Tecra Z50-A Motherboard Replacement, Motherboard: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5 mm screws using a Phillips #0 screwdriver.
  14. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 5 mm screws using a Phillips #0 screwdriver.
  15. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on plastic covering over the Wi-Fi card.
    • Disconnect the black and white coaxial cables from the Wi-Fi card.
  16. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the bundled red and black cable from its connector on the motherboard.
  17. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the black retaining flap using a pair of tweezers.
  18. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the tab on the right toward the top of the laptop.
  19. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the tab on the left toward the top of the laptop.
  20. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  21. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  22. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the charging port with tweezers.
  23. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up on the plastic tab.
  24. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull plug towards the bottom of the laptop.
  25. Toshiba Tecra Z50-A Motherboard Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the middle of the motherboard with your hands and lift up to remove it from the laptop.
Luis Juen Baez
crwdns2935283:010/25/21crwdne2935283:0
585 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-4, Sinclaire Fall 2021 crwdns2935289:0UMass Dartmouth, Team 2-4, Sinclaire Fall 2021crwdne2935289:0
UMASSD-SINCLAIRE-F21S2G4
crwdns2935297:022crwdne2935297:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 1,265
