Toshiba Tecra M3 Memory Upgrade
  1. Toshiba Tecra M3 Memory Upgrade, Remove Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop upside down, with the battery at the upper edge. While sliding the battery latches, push the battery away from you to slide it out of the laptop.
  2. Toshiba Tecra M3 Memory Upgrade, Remove Retaining Screw: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the battery is out, you have access to a small retaining screw at the bottom of the battery compartment. Remove this screw.
  3. Toshiba Tecra M3 Memory Upgrade, Remove Upper Keyboard Trim: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop right side up and open the lid. Carefully pry off the plastic keyboard trim (outlined in yellow). It comes off very easily once you remove the retaining screw (step 2).
  4. Toshiba Tecra M3 Memory Upgrade, Remove Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws at the top of the keyboard. After removing the screws, carefully slide the keyboard forward until the plastic fingers on its lower edge are free of the case. Then flip the keyboard toward you, taking care not to damage the ribbon cable connecting it to the laptop.
  5. Toshiba Tecra M3 Memory Upgrade, Remove Memory Access Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • A single screw holds a sheet metal memory access cover in place. Remove the screw and take off the cover.
  6. Toshiba Tecra M3 Memory Upgrade, Remove the Old Memory Modules: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove a memory module, gently slide the module's retaining clips toward the outside edges of the laptop. In the photo one of the retaining clips is hidden underneath the keyboard ribbon cable.
  7. Toshiba Tecra M3 Memory Upgrade, Insert New Memory Modules: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently insert the new memory modules into the slots where you removed the old memory. Note the slot in each module, which prevents you from inserting the memory module in the wrong orientation.
gordonhamachi
crwdns2935283:012/20/14crwdne2935283:0
4.161 crwdns2915208:0crwdne2915208:0
crwdns2935297:017crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,282
