Toshiba TECRA R940 Hard Drive Replacement
  1. Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the screw holding the back panel for RAM in place using a Phillips #0 screwdriver. Once loosened, lift the panel up and set it aside.
    • The screw holding the panel in place should not come completely out. If it does, do not be alarmed as it will still screw back in.
  2. Toshiba TECRA R940 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba TECRA R940 Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 11mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  3. Toshiba TECRA R940 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba TECRA R940 Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the hard drive from the left side and disconnect the SATA connector from the right side. Completely remove the hard drive.
Holly Strauch
crwdns2935283:009/23/18crwdne2935283:0
433 crwdns2915208:0crwdne2915208:0
Central Washington University, Team S1-G5, Pengilly Fall 2018 crwdns2935289:0Central Washington University, Team S1-G5, Pengilly Fall 2018crwdne2935289:0
CWU-PENGILLY-F18S1G5
crwdns2935297:021crwdne2935297:0
I cannot lift up the “back cover” (step 1). I’ve twirled the screw left for minutes and tried to lift up the panel using a small flathead screwdriver and it will not lift up. HELP!
Remy Secor - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,292
