Toshiba Satellite p875 s7200 Screen Replacement
  1. Toshiba Satellite p875 s7200 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift out the battery.
  2. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
  3. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6 mm screws around the edges with the Phillips head screw driver. Then remove the 6mm screw holding the disc drive into place.
    • Sliding out the disc drive will reveal the final two 4 mm screws on the bottom of the device.
  4. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over to begin the process of removing the keyboard.
    • Use the spudger to pop the keyboard off. Start at the bottom of the keyboard and work your way around.
  5. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips head screw driver to remove the last 6mm screws holding the case together.
    • The screws are held into elevated columns which are fairly easy to break. Be cautious when removing the screws.
    • After removing the keyboard and the screws, use the spudger around the edges of the laptop to remove the face plate.
  6. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips head screwdriver to remove the 5mm screws on the right speaker.
    • Repeat the process for the left side.
  7. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and disconnect the black and white display wires by pulling them upwards.
    • The second image shows the disconnected wires.
    • Flip the laptop back over and pull the black and white wires through their holes in the motherboard.
  8. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move the speakers out of the way after removing their holding screws.
    • Remove the two 4mm screws on the hinges on each side of the laptop.
  9. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the screw driver to remove the two black disks from the top corners of the display.
    • Remove the 5mm screws that were hidden behind the little black disks.
    • Use the spudger tool to pop the cover off of the edge.
  10. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3 mm screws holding the display in place. Repeat this step for both the left and right sides.
  11. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the display upwards to remove it.
  12. Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite p875 s7200 Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the screw driver to remove the six 3 mm screws holding the brackets and hinges onto the display.
    • Do not misplace these brackets because they will be used on the new screen.
Danny Amado
crwdns2935283:010/29/18crwdne2935283:0
823 crwdns2915208:0crwdne2915208:0
Baylor, Team S1-G3, Williams Fall 2018 crwdns2935289:0Baylor, Team S1-G3, Williams Fall 2018crwdne2935289:0
BU-WILLIAMS-F18S1G3
crwdns2942667:0crwdne2942667:0 1,183
