If your laptop gets hot and noisy when it is turned on, there may be a problem with the fan. This guide contains instructions for both checking the connection of, and replacing the fan of a Toshiba Satellite C650D computer.
Unplug the laptop and turn it off.
Flip the laptop upside down.
Locate the battery on the underside of the laptop.
Push the two latches away from the battery.
Slide the battery away from the laptop.
Locate the serial number on the battery to order a replacement.
Remove the fourteen 6.0mm and two 2.0mm Philip's #0 screws connecting the keyboard to the back.
Flip the computer over.
Use a nylon spudger to lift the keyboard.
Go around the edge of the keyboard and lift until the keyboard separates from the back.
Detach the ribbon cable that connects the keyboard to the motherboard.
Detach the cable connecting the fan to the motherboard.
Remove the one 3.0mm and one 5.0mm Philips #0 screws holding the fan in place.
Remove the fan by pulling it out slowly.
