In this guide you will learn how to remove the battery of your Toshiba Satellite U925T-S2120. If your battery is broken, you may need to replace it. Before beginning this guide you should have all tools that are listed.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the nine rubber grip pads on the back panel of the laptop.
Use a Philips #1 screwdriver to remove the nine 5.8 mm screws highlighted.
Remove the two 6.8 mm screws. Set aside.
Notice: The U920T need a T7 screwdriver for the top middle screw.
Remove the back panel by inserting the plastic opening tool into the seam of the laptop and pushing downwards.
Use the screwdriver to remove the two 3.4 mm screws highlighted.
Remove the black cable from the connector. Pull in the same direction as the black wiring runs.
Lift and remove the battery from the device with the iFixit opening tool.
