Toshiba Satellite U405D-S2902 RAM Replacement
  1. Toshiba Satellite U405D-S2902 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite U405D-S2902 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side.
    • Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • The screws will not actually come out from the panel but will be loose and let the panel come off.
    • Lift the left side of the panel to remove it.
  2. Toshiba Satellite U405D-S2902 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and pull back the two mounting clips on either side of the memory chip.
    • Be sure that when replacing the board, push down gently until the clips snap back in.
  3. Toshiba Satellite U405D-S2902 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite U405D-S2902 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
That's it for hardware, the remaining steps will depend on the software platform being run on your laptop.
Brandon Kirklen
crwdns2935283:001/11/13crwdne2935283:0
311 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-8, Maness Winter 2013 crwdns2935289:0Cal Poly, Team 7-8, Maness Winter 2013crwdne2935289:0
CPSU-MANESS-W13S7G8
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 706
