Toshiba Satellite S55T-B5335 Wi-Fi Adapter Replacement
  1. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Wi-Fi Adapter: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the pointed end of the Spudger, gently disconnect the antenna (white and black wires) from the Wi-Fi adapter.
  7. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 4 mm Phillips #1 screw holding the Wi-Fi adapter in place.
  8. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While grabbing the Wi-Fi adapter on both sides, gently pull away from the socket in the direction of the removed screw.
George Gillespie
crwdns2935283:009/15/16crwdne2935283:0
721 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-1, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 2-1, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S2G1
George, do you know where the graphics chip is at on that motherboard?
Any Where - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,373
