Toshiba Satellite S55T-B5335 Touchpad Replacement
  1. Toshiba Satellite S55T-B5335 Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Touchpad Replacement, Bottom Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite S55T-B5335 Touchpad Replacement, Bottom Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Touchpad Replacement, Touchpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite S55T-B5335 Touchpad Replacement, Touchpad: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, lift the black tab that holds the touchpad ribbon cable in place.
    • Using tweezers, pull gently on the purple tab to separate the ribbon cable from the connector.
  7. Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently push the back side of the touchpad in order to create a gap on the top side of the touchpad.
  8. Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, hold the touchpad up in the position from step 2.
    • While the touchpad is held up, use a spudger to scrape loose the adhesive holding the touchpad to the base.
  9. Toshiba Satellite S55T-B5335 Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the adhesive is separated enough from the touchpad, peel it back and remove it.
George Gillespie
crwdns2935283:009/15/16crwdne2935283:0
721 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-1, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 2-1, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S2G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 1,664
