The bottom cover will need to be removed in order to access replaceable parts inside of the laptop. This is a simple process that requires the removal of ten easily removed screws in addition to the battery removal.
Remove the two 7 mm Phillips #1 screws that hold the battery in place.
Remove the ten 7 mm Phillips #1 screws that secure the back cover.
Wedge the tip of a plastic opening tool between the back cover and the metal frame.
Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
