Removing the battery is the first step in many instances where the laptop needs to be repaired or battery needs to be replaced. This is a simple process that requires only two screws to be removed. Please refer to the Battery Troubleshooting Guide to determine if your cooling fan needs to be replaced.
Remove the two 7 mm Phillips #1 screws that hold the battery in place.
