A guide to replace the SUB/SD card/headphone jack within your Toshiba Radius.
Remove the two rubber feet closest to the hinge with a plastic opening tool.
Remove the twelve M2x4mm PH0 Philips head screws.
Loosen the back cover with a plastic opening tool.
Carefully lift open the cover.
Remove the attached purple ribbon cable underneath the cover.
Unscrew the two screws holding the panel of the UBS/SD card/headphone jack
disconnect the cable shown from the motherboard
disconnect the cable attached to the top of the USB/SD card/headphone jack interface
