Toshiba Satellite Radius P55W-B5220 Motherboard Replacement
  1. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, remove the two rubber feet closest to the hinge.
  2. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 12 M2x4mm PH0 Philips screws.
  3. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Near the hinges, wedge a plastic opening tool under the back panel.
  4. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unlatch the LED indicator from the back panel.
  5. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a P0 Philips head screwdriver, Remove the four M2x2.5mm P0 Philips screws from the battery.
  6. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery.
    • Disconnect the battery.
  7. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the ribbon cable of the touchpad from the motherboard.
  8. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two M2x2.5mm P0 Philips screws from the fan.
  9. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the fan cables.
    • Carefully unhook the wires from the base of the fan.
  10. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four M2x4mm PH0 Philips screws from the CPU mounts on the motherboard.
  11. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the heatsink off the CPU.
    • Avoid bending or kinking the tubing.
    • Delicately lift the fan out with the heatsink.
  12. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the M2x2.5mm P0 Philips screw from the USB controller.
  13. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the USB controller from the motherboard.
    • Detach the USB controller from the motherboard.
  14. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the left speaker from the motherboard.
  15. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two M2x4mm PH0 Philips screws for the speaker mounts.
  16. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unhook the speaker from under the hinge cable mounts.
  17. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unhook the right speaker cable from the motherboard.
  18. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the copper tape from the speaker cord.
  19. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unhook the speaker cables from under the catch under the hinge.
  20. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight M2x2.5mm P0 Philips screws from the motherboard.
  21. Toshiba Satellite Radius P55W-B5220 Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
Nicole Kohm
crwdns2935283:009/20/17crwdne2935283:0
131 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S5-G6, Thomas Fall 2017 crwdns2935289:0University of North Texas, Team S5-G6, Thomas Fall 2017crwdne2935289:0
UNT-THOMAS-F17S5G6
crwdns2942667:0crwdne2942667:0 1,863
