The hard drive is a high-capacity, self-contained storage device containing a read-write mechanism. If defective, this guide will instruct you on how to remove and replace your hard drive.
Remove the two rubber feet closest to the hinge with a plastic opening tool
Remove the twelve M2x4mm PH0 Philips head screws.
Loosen the back cover with a opening tool.
Carefully lift open the cover.
Remove the attached purple ribbon cable underneath the cover.
Gently lift up the black tab attached to the strip
