The battery is the power source for your laptop. If defective, this guide will instruct you on how to remove and replace your battery.
Remove the two rubber feet closest to the hinge with a plastic opening tool.
Remove the twelve M2x4mm PH0 Philips head screws.
Loosen the back cover with a plastic opening tool.
Carefully lift open the cover.
Remove the attached purple ribbon cable underneath the cover.
Remove the four M2x2.5mm P0 Philips head screws.
Pinch the attached cables and carefully pull away to remove the battery.
