Toshiba Satellite P855-S5312 Hinge Replacement
  1. Toshiba Satellite P855-S5312 Hinge  Replacement, Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement, Fan: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement, Fan: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the one 1.5mm screw using a Philips #0 screwdriver holding the L shape panel.
    • Pry up the panel to gain access to hidden screws.
  2. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fourteen (14) screws using a Philips #0 screwdriver for the 1.5mm screws on the underside of casing.
  3. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the nine 1.5mm screws using a Philips #0 screwdriver under the keyboard with the F6 printed next to them.
    • Unplug the three no-fuss ribbon cable connector cables by gently pulling on them away from you towards the keyboard.
  4. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry apart the casing with the plastic opening tool.
    • Removing the cover under keyboard.
  5. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the single no-fuss cable connector using the plastic opening tool pushing the edges towards the fan.
    • Unscrew the two 1.5mm screws using a Philips #0 screwdriver by the head mounting holding down the fan.
    • Pull the fan up and remove it from the device.
  6. Toshiba Satellite P855-S5312 Hinge  Replacement, Screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement, Screen: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement, Screen: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn laptop upside down with the spine facing towards you and locate the microchip.
    • Remove the white and black sliding connector wires by prying upward with tweezers gently pulling the black and white wires upwards.
  7. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the single ZIF connector ribbon by gently pulling up.
    • Pull the white and black wires through from the underside of device.
  8. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four hinges mounting the 1.5mm screws on each side from casing using a Philips #0 screwdriver.
    • Remove entire screen assembly from casing.
  9. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two black sticker covers on the bottom of both sides of the monitor
    • Using a pair of tweezers, carefully remove black stickers concealing two screws
  10. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a prying tool, carefully pry along the edges of the screen cover
  11. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 1.5mm screws at the bottom of monitor using a Philips #0 screwdriver.
  12. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With all the edges of the screen cover pried up, carefully remove the screen cover.
  13. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Philips #0 screwdriver, remove the four 1.5mm screws at the corners of the screen.
  14. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • At the top of the screen, using the tweezers, remove the ZIF ribbon connector by gently pushing it up.
  15. Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen from the device.
    • Make sure to be carful because the screen is very fragile.
  16. Toshiba Satellite P855-S5312 Hinge  Replacement, Hinge: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement, Hinge: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P855-S5312 Hinge  Replacement, Hinge: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three screws on the sides of the screen using the Philips #0 screwdriver.
    • Once unscrewed, pull the frame off along with the hinge.
James Wiehle
crwdns2935283:010/02/17crwdne2935283:0
236 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S10-G2, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S10-G2, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S10G2
crwdns2942667:0crwdne2942667:0 1,782
