Use this guide to remove the Toshiba Satellite P55t-A5116 RAM.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Close laptop and turn it upside down
Remove the 14 circular rubber covers with tweezers along with one smaller more cylindrical rubber cover.
Using the #PH0 screw head, remove 14 (5.7 mm) screws from the back casing.
Gently pry off the bottom case with the plastic opening tools.
Find the seam between the back case and the rest of the laptop casing.
Locate the RAM cover on the back of the Laptop.
Using the #PH0 screw head, remove 1 (5.7mm) screw.
Use the plastic opening tool to remove the RAM cover.
Pull out the latches on either side.
The RAM should pop up.
Remove the RAM.
Repeat for other side.
I’m confused… it only seems like Step 4 and Step 5 are necessary. Does the battery need to be removed before replacing the RAM? If that’s why Steps 1-3 are there, there’s a lot of steps/information missing. It just goes from “take off the bottom case” to “remove the RAM cover of intact laptop”.
