Toshiba Satellite P55W-C5200X Fan Replacement
  1. Toshiba Satellite P55W-C5200X Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P55W-C5200X Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P55W-C5200X Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Phillips #00 screwdriver to remove the ten 4.0 mm screws located at the bottom of the laptop.
  2. Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the black nylon spudger to pry the back casing along the edges.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
  3. Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 6.0 mm screws that hold the battery in place using the JIS #000 screwdriver.
  4. Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  5. Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the battery from your device.
  6. Toshiba Satellite P55W-C5200X Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P55W-C5200X Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Toshiba Satellite P55W-C5200X Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 4.0 mm screws using the Phillips #00 screwdriver.
    • Remove the four 2.0 mm screws using the Phillips #0 screwdriver.
  7. Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fan cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  8. Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Toshiba Satellite P55W-C5200X Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the fan from your device.
Marley Pusey
crwdns2935283:003/27/19crwdne2935283:0
147 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G2, Botvin Fall 2019 crwdns2935289:0UMass Dartmouth, Team S1-G2, Botvin Fall 2019crwdne2935289:0
UMASSD-BOTVIN-F19S1G2
crwdns2942667:0crwdne2942667:0 707
