This guide will show you how to take off the back cover of your Toshiba Satellite. We will first uncover all of the rubber stoppers that are hiding the screws. After, we will unscrew these screws and carefully open the back of the laptop.
Locate all rubber plugs on the bottom of the laptop. These will need to be removed with a pointed object like the Spudger.
After all rubber plugs are removed, use a Phillip's head screw driver to unscrew all previously covered screws.
After all screws have been removed, pry the bottom cover of your laptop starting at the front edge.
Slowly work your way around the laptop until the back cover is completely off.
