The wifi module connects the device to wireless internet networks. Be careful when handling the wifi module.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Turn over the laptop and proceed to take out the seven 5mm silver JIS #1 head screws. If some of the screws are difficult to take out use the tweezers to help.
Use the screwdriver to take out the three 5mm black JIS #1 head screws that are located on the hinge.
Use the spudger to pry under the back cover until it pops off.
Locate the Wi-Fi module in the device which is located next to the ram.
Unscrew the 3mm JIS head screw with J1#1. This screw is holding the Wi-Fi module to the device
Remove the black and white wires that are connected to the device by gently pulling on it.
